Serial JJG0191450
First off, not much of a mechanic, so bear with me. I will probably have to look up how to do anything suggested.
Problem presented as you needed to slightly rev the engine a hair for it to engage and would move fine then. Restarted unit a few times, no change, drove it back to the barn. Now it won’t even start moving after reving.
I believe this had a problem with the clutch cut out where it prevented it from starting at one point.
I pulled the relay to the shuttle interlock and it has a rattle to it. Not sure if that means anything.
Starting transmission fuse does not seem blown, however it is a 15a and not a 10a shown on the chart.
Some questions I saw on other posts were whether the drive shaft spins when shifted when in gear and if the rear wheels spin when off the ground and if they have resistance. No to the drive shaft, yes to spin and yes to resistance.
Also putting into 4wd does not help.
