swangerenterprises
I have a Deere 490E excavator with 10400 hours on it. The machine turns fine when sitting on the flat or going down hill, but is very hard to turn on any kind of up hill grade. Also if you try to spin one track forward and one backwards they do not spin very fast. Another issue is that when tracking straight line the right side all but stops occasionally. If you just periodically let off the stick a little it doesn't seem to do it. I have already rebuilt the rotary manifold and that made a big difference on turning on the flat and changing between travel speeds. It switches through travel speeds just fine. I have only used the machine about 5 hours since i have owned it for several months. Before I bought it, the machine was through a Deere shop and had all of the pump pressures checked (I was told) and i believe the DP sensor replaced. If you put the bucket against something and track it seems to have good track power (doesn't bog or slow down). I talked to a gentleman who has a sales/repair shop and he told me that the 490Es had weak drive motors from factory and never turned well. The machine has 27.5" pads if that makes a difference. Just looking for some things to check. i have only ran newer cat equipment and dont have experience with Deere. Thanks
