rmllarue91
99c5555 hey hef kinda weird one here 988f2 shut off as operator was leveling modified. Cranks no oil pressure on gauge and guage flashing. Double checked with a digital low pressure gauge I use for oil fuel low pressure. Nothing not a psi. But it I pull plug it will half a$$ pump oil. It's flows slow with no pressure. Checked bypasses nothing wrong. Pulled pan and pump looks fine. Relief plunger was in bottom of bore and spring was in tacked. Gear on crank is firmly attached. Same with gear on from of oil pump. Suction and supply tubes check out. There is uniform metal flakes in filters looks like bearing material not aluminum. It's not magnetic. Maybe 1-3 flakes per fold of oil filter media. It seems oil pump is supplying oil just no resistance to build pressure.... I don't see any damage that can dump all oil flow back to sump. Does a heiu motor need heui resistance to build oil pressure for rotating group? Seems far fetched to me. Any thoughts I'm scratching my head. I feel like I over looked someone but I'm not seeing it duh. lol
