PeteG
Hi,
We have a Deere 331G serial number 304482. It’s been putting up code 157.18, Fuel Rail Pressure Moderately Low. I tried filter changes, as well as a bit of diesel additive and biocide as I was following another thread on here with similar issues, but no luck so far. When in service mode it shows:
1 361.0
3 361.2
And through diagnostics I can see the fuel pressure sensor at 2600 reading 100-130 MPa with up to 3V. When the machine throws the code, fuel pressure jumps down to 70+/- with 2v. The other odd thing is it is as if the machine idles down, it doesn’t stutter at all. It’s been doing this for a few weeks now, slowly getting more prevalent. Today ran it for an hour and it popped up towards the end. I’ve been clearing the codes after I make small changes to see if it had an effect, but so far it keeps popping the same code and derating.
Dealer is a ways out for field service schedule so would like to get a head start if I can. There suggestion was to check the fuel pressure sensor wires and reconnect to sensor, which worked for one day but the code popped up again. Thank you for any suggestions.
1 361.0
3 361.2
