Hello All
What started as a decision to remove the hydraulic pipes from the boom to clean the rust off them and repaint them has turned into a repin/rebush of some of the pivots as well as a crack repair on the stick.
The problem is the main pivot for the boom swing is worn. The pin is badly worn and the bushes slightly worn but the worst part is the bores through the housing are worn as well even though the pin does not rotate in them. The only solution I can see is to get them bored out and a hardened bush pressed in. My concern is that if I machine the bores out to suit a bush will there be enough thickness left. The pin should be 90mm and the nearest hardened bush I can get has an OD of 100mm so that would require 5mm removed from the thinnest section. Currently the top hole measured up at 91.5mm and the bottom at 90.5mm. I could maybe bore the new hole offset so there is little or no material removed at the thinnest part but that will change the dynamics of the linkage.
What do you all think? Anybody had this issue before?
Also one day I would like to fit a hydraulic thumb to this machine but it lacks the mounting lug for the cylinder. I seem to recall reading about a weld procedure and a kit for the mount but I can't find anything now. Does anybody know about this kit and procedure? Mine has the long heavy duty stick on it not the standard.
Regards
Phil
Regards
Phil
