304C CR Electrical issue
05f150fx4
Earth
Looking for help with my 304C CR. Serial number FPK03541. The machine will randomly go completely dead. Then it will be fine for a month or so after a jump. I replaced the alternator and belt about a month and a half ago, replaced the battery with a CAT battery in the fall. Still having issues with it going completely dead. Today after jumping it to try and get a project done, the thumb would not work and the machine would not turn off when the key was turned off and removed. Any suggestions on where to begin? Thanks in advance.
Steve Frazier
Founder
Staff member
LaGrangeville, N.Y.
I don't claim to be an expert on this topic but if it were me I'd start by checking all of the main ground lugs for corrosion. So many times electrical gremlins can be traced to a bad ground.
rmllarue91
northeast pa
field technician
What helps finding battery draws is looking for warm fuses and relays when machine is cold
kshansen
Central New York, USA
Very true. Don't matter how many volts or amps that are in the battery if they can not find their way back to the battery they are not going to do any work!
