279D right side drive motor issue
Tonkatoy
Southeast Ohio
I have a 279D sn GTL04445 and the right side is locked up. It made a bit of a grinding sound, and the abnormal speed warning flashed. I think it is something in the drive motor. I have taken the drive motor out and accidentally cut two wires on the speed sensor doing so. Should the drive motor turn freely if the parking brake is released and the drive hydraulic lines are not hooked up? I was going to try and test the motor to see if it would spin with park brake released with the other lines capped. Would a faulty speed senor engage the park brake on that side? Also I was thinking that Cat shoudl be able to test the motor on a test bed, is that the case? In the event it needs replaced any thoughts on cat reman vs new? thanks.
First thing would be to look at the hydraulic filter. Can you see particles in the filter or the housing.? If not then see below.....
Did you take a look in the planetary side.? Drain the oil by removing the plug on the outer case. See if it is full of sparkly bits. Maybe that is where your grinding noise is coming from.?
There is no such thing as a "test bed". All the dealer would do is open it up for inspection just the same way that you are proposing to do, and remember they would charge you $150/hr for the privilege. Personally I would suggest to open up the planetary yourself first.
I'll try to upload a parts illustration of the Motor Gp but it doesn't want to co-operate at the moment.
92U 3406
Western Canuckistan
Wrench Bender
I would put the machine on stands and run a case drain check on that side. A healthy motor will put out about a pencil lead sized trickle when in normal operation, slightly more when stalled (Cat does not have a case drain volume spec, at least that was what I was told by Cat's tech team anyways). If you're getting a lot of case drain flow then odds are the motor has failed or is failing.
If the motor case drain flow is good, I'd pull the cover off the final drive and see if something came apart. If it looks good, you're probably going to have to pull the motor/drive and disassemble it.
Tones
Ubique
The first thing to do is check the condition of the planetary oil. If it's good then do the casedrain flow check as mentioned above. Testing and checking is a lot cheaper than guessing.
Tonkatoy
Southeast Ohio
I will check filter tomorrow. Is there any special procedure for taking off the outer cover? From what diagrams I have seen the motor end of the housing has springs inside.
Tonkatoy
Southeast Ohio
Also the reason i asked about testing was that i saw a video of a hydraulics shop testing one in a vice with a test rig. Just out of curiosity, if you released the park brake how freely should the motor turn with the other hydraulic lines off?
Junkyard
Claremore, OK
Field Mechanic
It won’t turn very free even with the brake released. There’s a lot of stuff in there. I’ve had them break the swash plate and lock up. Speed sensor won’t make the brake lock. Tear it apart and see whatcha got.
  • 299 Drive Motor Assemble.pdf
Yes, but don't go into the motor end yet, go into the opposite end. All you have to do for a start is to remove the plug #9 and check the oil condition for sparklies and/or metallic chunks. After draining the oil there is a large circlip holding the cover in place. It's shown as part of #2, which from right to left is the circlip, the cover, and an O-Ring seal on the inside.
That would allow you to inspect the planetary assembly #3.
Tonkatoy
Southeast Ohio
Took the plugs out of the planetary side and there is metal shards inside. My largest snap ring pliers are not up to removing the retaining clip so need to figure something out there. Amazon sells a set by Lang that looks like they will work.
Tonkatoy
Southeast Ohio
Got the end off today, several of the gears have chipped, missing teeth. At this point I am not sure if it is worth the time and money to replace gears, get a reman unit, or just purchase a new one.
Well I went to SIS to see what a drive motor is running now a days in order to give you an idea of cost new but on both of our 279D serial #'s it said contact dealer.
IIRC several years ago we had one replaced under the PT warranty and it was around $5K including R&R at the Cat house.
Tonkatoy
Southeast Ohio
New lists as $6375 and reman at $4143 with a $2231 core. The fine print says they have to inspect core to see if they will take it. Gear kit is $3100 or so. How do you feel about cat reman parts Nige?
I would suggest to ask what the Core Acceptance Criteria is. A lot of components have to freely turn 2 full revolutions - which your motor obviously won’t unless you pull all the planetary gears out of it (now there’s an idea, but I didn’t say that.!) before you hand it over. Also there could be a clause that states components must be in original condition with no evidence of recent disassembly before being handed in as a Core. I’d guess your motor shows clear signs of the cover having been off it. It will pay you to check what specific conditions apply to it.
How good the value of Reman would be in your circumstances would depend on how many hours a year your machine clocks and what warranty is given on the replacement motor.
If the hydraulic side of the motor is good (cut the filter & check for particles if you haven’t already) then maybe a new planetary gear set would be a cost-effective solution. Hard to say without having the parts in front of you. Also the total hours on the machine would play a part. I don’t think that you ever mentioned the hourmeter reading.
It's a bit late to ask now but was the oil you drained out of the planetary compartment black.?
That compartment takes 1 litre of full synthetic 75W/140 per side. There have been a lot of posters on this forum recommending to change that oil every time you change the engine oil because the quantity is so small and the fact the oil is under so much stress. See this thread.
savman
LaGrange, GA
I changed my final drives (289d3) at 250 hours per the dealer recs and there was enough flakes in there I got on the phone and sent pics/email of what came out. He swore up and down that's normal wear but man there was some metal in that fluid.
They recommend every 500 hours after the initial 250 but I change mine every 250 hours. That synthetic stuff isn't that much money and it's super easy to do. Cheap insurance imo.
Buddy of mine was there when I did the initial 250 hour change and he was shocked at what came out as well.....then he said....well I guess I should change mine too; problem is he has 1300 hours on a 299 and has never changed it. Oops.
