Tonkatoy
I have a 279D sn GTL04445 and the right side is locked up. It made a bit of a grinding sound, and the abnormal speed warning flashed. I think it is something in the drive motor. I have taken the drive motor out and accidentally cut two wires on the speed sensor doing so. Should the drive motor turn freely if the parking brake is released and the drive hydraulic lines are not hooked up? I was going to try and test the motor to see if it would spin with park brake released with the other lines capped. Would a faulty speed senor engage the park brake on that side? Also I was thinking that Cat shoudl be able to test the motor on a test bed, is that the case? In the event it needs replaced any thoughts on cat reman vs new? thanks.
