theyre nice machines to run, and work on. theyre smooth and pretty quick, id take one over a lot of other tracked skid steers. however the under carriage is costly... if you are doing dirt work and not running over a lot of stone or demolition debris the tracks should last you a while. if you are the only operator and keep from digging into a pile allowing dirt or stone to get into the boogie wheels the bearings will last a while, but if a handful of people operate it and dont keep the tracks clean/ out of stone piles then the wheels will get chewed up and the bearings will go bad. either way youll end up having to replace bearings, wheels, and tracks and theres a special tool that makes life a lot easier id recommend buying that. the service and parts side of the machine- its way easier and nicer to work on than lets say a john deere, tak, gehl, or new holland. theres plenty of room to work on it and parts are easy to get. that all being said the undercarriage will cost you around $8 per hour in parts especially if you arent careful, but thats with any CTL for the most part. you might look at a 247, ive heard that those and the 287 i believe or what ever other radial arm one cat makes are easier on the undercarriage because the lifting weight is more centered on the machine and the rear boogie wheel doesnt take as much of a beating from the extra weight.
hope that helps, but if you can get one for a decent price and the undercarriage is in good shape it should treat you well
