I'd like to rule out that .9 volts at your solenoid isn't a short to power. I know you've checked continuity but we heading down an ECM replacement path, so the checks are worth it. We also need to rule out the newly installed solenoids haven't been fried.
Pick the easiest solenoid to access, just worry about that one from now on. Remove solenoid, check resistance again, make sure it's close to spec as mentioned on the previous page (post #7 I think). If it is, continue on...
Use a pin-out tool and remove that H807 wire at #4 of the J2 ECM plug completely, let it dangle. Use a new wire and run it directly to #2 of the solenoid we're concentrating on. The wire in position #1 on that solenoid is verified as working correctly, so leave that exactly where it is.
Cycle isolator, key on, don't do anything else. The two other solenoids will go -5 current below normal since they're open circuit now. The solenoid you chose to concentrate on should have zero codes active. If it still has a -6 current above normal you have an ECM failure.
Let us know what you find.
