Y'all may remember my project from here. I've almost finished rebuilding a 299D2 after buying it as a burnout from a junqueyard.
But I have not been able to figure out what's wrong with Aux 1 & 2 lines running down the arm. I have a grapple on the machine which just won't grapple. It uses the two smaller connections, Aux 1 & 2.
It appears that Aux 1 is supposed to pressurize to open the jaws, and Aux 2 is supposed to pressurize to close, but I'm getting zero pressure in each, as evidenced by loosening the lines at the cylinders.
So these Aux lines trace back to the implement control on the bulkhead and are controlled by two solenoids. I thought at first that maybe it just needs primed, but then, everything else run by the implement controller is working. (arms lift, tilt)
So I put pins through the wires going to the solenoids and connected a multimeter. The solenoids are run by PWM (pulse-width modulation) so I set the meter to AC voltage. When pulling the right joystick thumbwheel I get 6vAC on Aux1, which doesn't seem like enough. When pushing the thumbwheel I get only microvolts on Aux2, effectively nothing.
Using the prints to trace back the wiring it seems that Aux 1 & 2 signals come direct from the ECM! How can the ECM provide enough current? Well apparently it must.
So I decided that this must be a calibration issue, as I remembered going through current calibrations for the lift and tilt. I ran ET, and the current min and max settings (which I'd downloaded in this serial#'s factory setting .xml file and loaded to the ECM) did not seem out of line. But I set max higher on Aux1 & 2 to 1.2 amps, a bit high, and min current higher to .8 amps. Still did not work the grapple. Then I set max on both to 1.5 amps and min to 1 amp, way high. Still no action.
Well that blew my last theory out of the water.
Has anyone seen this behavior before?
