scottrussell09
I have a cat 289D that is only displaying a few red indicator lights up in the top right corner. The CAT display screen doesnt light up. Machine will crank over, but does not start.
Strange thing is, the lights (parking brake light, hydraulic pressure light) are on all the time, even with the key off. The battery also has a heavy draw on it all the time - dead within 24 hours.
Im leaning towards the ECM. Battery is good, confirmed with a second working battery. Charged overnight to full system voltage - so its not a weak or low voltage issue. Ive pulled every fuse out of the cab to ensure its not a strange accessory issue. This machine doesnt have a radio, so it cant be the known short. Have any ideas on what to check next?
ECU part number is 1J770-59051. Secondary part number on it is 112500-1090. ECU also shows an engine model code of V3307-CR-TE4B-CTP-1 ( i only post this portion because its on my lap right now. Ive pulled it from the machine.
I did test without an ECM to see if the phantom draw still existed. It is no longer drawing power and all indicator lights are off now as well. I dont know what all runs through the ECM - this may be expected behavior. Im still getting the electrical system down on this machine.
Thanks!
Thanks!
