I have a 2013 Case 580N. With the rear controls to bring them back towards the seat for a better comfort level for whatever reason wont move when you squeeze the adjustment handle. I've crawled under the backhoe, and took a look at the linkage, and it seems clean from dirt/mud. When under the unit i'll have someone try moving the joysticks, and you can see that there is a little movement, but wont work. If someone has any incite, or a schematic showing the components I can check that would help. Thank you
