2012 Cat 314d lcr oil pressure low electrical issue
Owenfred
California
No there is no event code for oil pressure because the pressure is in spec. Just the pesky red alarm on the screen. I confirmed the monitor is working by manually applying voltage and grounding without the ECM connected... The warning triggers on/off as expected.
The alarm
Owenfred
California
Nothing obvious in configuration screen... Man, this one's a doozy!
Try expnading the "System Settings" tab for the engine ECM located 2 above "Configuration Group 1" that you expanded in that photo.
Also go through and expand each of the tabs under the VIMS Main Module section, just for a look. VIMS is the machine Monitor System.
Owenfred
California
I think that is expanded.
Unless I'm missing some kind of licensing or key for cat et system maybe this is the issue why there are not many settings.
Owenfred
California
Nothing obvious to me except the external maintenance thing, but that's disabled...
Owenfred
California
Must be an open circuit on the wire. Bummer and it's a big PITA to get to the ECM plugs on the engine to test it. I'm feeling lazy at this point and might just say leave it alone..
