Hi I got a 272c that when i engage the stick won't lift does not even make the pump make noise responds to lowering or tilting the bucket and will drive around. in mode 1 if I go to mode 2 still same Symptom.wont lift the arms. Will do everything else.
Pulled the joystick out to inspect the sensor still like new was changed last yr as it was chewed up.
Checked all the fuses all the relays appear to work.
I'm guessing this is prolly a selinoid has 2300 hours on it.
Nearest cat dealer is a 4hr drive.
Any advice on trouble shooting would be nice.
No warning lights are present on the panel like last yr when the stick went bad. There's no computer display in this unit and no code reader on site still need to find one for decent price.
Told when it stopped working it started being intermittent for few minutes then stopped responding to the joysticks request for lifting.
