David Nelan
Loader won’t lift weight. It will raise the bucket but stops lifting with weight in the bucket.
Trouble shooting and work done so far is:
*New lift cylinder seals
*New relief valve (control valve)
*Filters cleaned
*Cleaned BIC check valve screen and new O rings
*Tilt works
*Auxiliary starts and stops
*Foot controls are not locked
*Load check valve plugs cleaned and new O rings, spring and poppet are fine
NOTE: Port relief valves on the machine look to be plug style rather than full size valves. Not sure if it’s meant to look like that but online pictures show valves that are longer.
*Filters cleaned
*Tilt works
