JCB-214-2002
I've read a few threads on this topic in the forums but my symptoms dont seem to be the same. A few never posted the final outcome.
Backhoe transmission has been working fine for the last 400 hours. Since I purchased it.
Now when I accelerate (Primarily in 3 and 4th gear on a grade) the transmission lights illuminate and I get a buzzer. If i let off the accelerator, both stop. If I downshift to 2nd gear it stops.
It appears to happen mainly when I am in 3-4 gear and start off with heavy engine load. It also happens when going up an incline where I need to press the accelerator harder. Again, laying off the accelerator and it will stop buzzing, lights go out.
When the light and buzzer are on, if I press the accelerator harder, the machine does speed up even though it is buzzing at me.
I changed the trans oil and filter today. I did not see a strainer when I pulled the oval plate on the bottom to drain the oil.
Still same symptoms
Anyone have a like experience or know where I can check next?
2002 JCB 214-4T
Ser: 903000 series
Taking it to a dealership is too expensive for me right now.
Thanks
Still same symptoms
2002 JCB 214-4T
Ser: 903000 series
Thanks
