Wes Jackson
The engine started smoking really bad suddenly,I have eliminated the turbo as the problem and removed the exaust manifold and smoke and small droplets of oil are coming from number 3 cylinder. I do not have a compression gauge to check the compression but the engine is not skipping and has very little blow by. When I crack the injector line the engine skips as it should. I have already swapped injectors with the 1 next to it, is there anything in the head that could cause this, valve guide seal maybe?
