1986 Case 580e boom cylinder seal
Nick Tonelli
NH
Hi all- with the help of this forum I tackled the job of replacing a badly leaking book cyl on my new to me case 580e. I purchased the seal kit from HW part store using the stamped number on the cylinder nut. Everything went together fine until the last seal the “wiper” or whatever it is called that is placed on very end. It won’t fit at all due to a machined ridge it seems like the OD of the metal seal is too large. I even bought another kit from a separate supplier and had same issue. Am I missing something here? Seems to be much too tight of clearance to just bash it on
stinky64
java center ny
Don't feel bad, I was in the process of rebuilding all the cylinders on my machine when one of the neighbors stopped by and we started yapping about stuff,an hour later I continued with the job at hand. All of the wiper seals on my machine are the same color but one, guess why.:rolleyes: WTF
It sucks getting distracted when you're in the middle of repairing something. Sometimes you just have to forget about anything else and concentrate on the job at hand.
stinky64
java center ny
Kinda tough to concentrate when the feller causing the distraction has a fresh box of ice cold beer in his hand...:D
All the more reason to stay concentrated when working on something critical. Have a beer when you're finished.
My only problem is when you wake up the next morning and are pleasantly surprised someone finished the job and you have no recollection that it was you.
Did that one time swapping winter tires on and had to pull caps to check lug nuts to make sure I torqued them lol.
Sure it won’t be the last time.
