Good evening Guys!
I got a call from the injection pump shop today saying my stuff was ready, YAY!
When I went to pick it up I almost needed 2 checks to pay for it!
The total was so much there was almost not enough writing space to write it all on one!
This guy as I said earlier is the injection pump guru in our area, he has been building pumps since he finished his training in 1964 and he can build them with his eyes closed almost. When you install a pump that he has built they are fine tuned and a new pump is not any better than one he has gone through.
But he will forever more kill your pocketbook as he did mine today!!!
He totally rebuilt the pump, he also cleaned, set pressure, and tested 5 injectors, and replaced one that I damaged removing it. I figured that one would have to be replaced but that was my fault totally. It was stuck and I worked and worked with it trying to remove it until I got it out. I should have waited until I pulled the head and then I would not have damaged it.
Have I ever mentioned "Hind Sight"?
Anyway the total was $2856.
I am curious to know how that compares to what you Guys pay for that type work.
I had certainly not planned to spend that money because it was running with the pump when I bought it. However I could not tell how well it was running due to the knock being so bad and the #4 cylinder (which was also where the crank was broken) was not firing. But when I pulled it down all of the other cylinders were firing and it would crank if I just bumped the starter, even with #4 not firing so I was thinking the pump was in good shape.
But what do I know about injection pumps? Nothing , other than judging by how quickly it cranked even with one cylinder not firing.
I wish I had waited on having the pump built until I saw how it ran when I got it back together and see if everything else worked on it. But that is spilt milk now and hopefully my feeling will not be still hurting so bad about that unexpected investment in a few days or weeks.
Okay now that I have finished whining about how much that was I will post a couple of pics below of my new pump and it installed, which I am really happy about.
Oh, let me whine one more time
that pump cost me almost as much as the machine! Whine Whine!
Later Guys!
B-C
