ebath, I do not understand your confusion on the post where I said "the starter should be activated only by the gearshift lever movement"
The neutral start switch is a momentary switch designed to be the main start switch, the lever does not have a position it locks in for start, you push against a spring when using the gear lever to activate the NS switch, having to do multiple functions to start the engine is redundant. AS I previously stated, YOU DISCONNECT A VITAL SAFETY FEATURE AT UR OWN RISK IF THE STARTER CAN BE ENGAGED OTHER THAN BY THE START POSITION ON THE GEARSHIFT. Voltage should go directly from the IGN post on the IGN switch to a terminal on the NS, and then from the other terminal of the NS directly to the solenoid. However, If you desire for some reason to have to do two or three things at once, for me personally, turning the IGN on and activating the NS via the gearshift lever is easy. A push button was not ever used and was probably installed to bypass the NS. If using a nonstandard switch without a preheat function the push button could used to activate that solenoid. I am sorry if my original post was not clear enough.
If the original Prestolite alternator is functional the exciter wire fastens to the terminal with the wire coming from the regulator and the big terminal either directly to the Battery terminal on the starter or back to the dash if an ammeter is used then from the ammeter back to the Battery wire. The energizer wire from the IGN terminal on the switch would have a warning light in the wire that mounts in the dash and voltage goes through the bulb to the little terminal of the alternator. In a factory setup the bulb wire and socket assembly would have a 75 OHM resistor strapped across the bulb to keep the charging system functional in case of bulb failure.
Personally, unless originality is paramount to you I would simplify the system by doing away with the ammeter and using a voltmeter in its place, the voltmeter is just as telling as to system performance and eliminates a heavy wire to and from the gage, a voltmeter is a very low current draw and simply goes from IGN terminal to a good ground. With a voltmeter you can tell that the system is working by seeing if the voltage stays in the 14 V range with all the loads applied.
It may be of some interest to you guys to go over to YTMAG site and access the CaseDB forum, there is a fellow creating dashes with individual gages instead of a cluster and they look very nice.
580CK, In most instances the bushing seized in the tachs and people very seldom had them repaired, occasionally they could be loosened up and relubed but as time went on and generators were replaced with other gennys without the threaded armature for the small drive or the gearbox pattern in the end plate the tachs became useless.
On the CaseDB forum mentioned one of the suppliers has a modern alternator with the generator style tach drive installed but I always wondered about the accuracy as most times a pulley change has to be made to accept the alternator to get the belt tension. Maybe accuracy is not as important than just seeing everything working and that's ok too.
I believe in extremely cold weather it may be beneficial to depress the clutch to start because of oil drag in the gearboxes possibly but depressing the clutch pedal causes a force to be applied to the crankshaft thrust bearing is a standard shift and on a PS unit I think there is nothing to be gained. On as standard shuttle just putting the shuttle in neutral will free up the whole drive train but the input shaft. I guess whatever we think works for us.
