16b engine repower
td25c
indiana
Here are pictures of when I repowerd My fiat-allis hd 16b dozer.It broke the crank in the fiat motor and I installed a big cam 855 cummins.
td25c
indiana
here are the pictures.
td25c
indiana
More pics.
td25c
indiana
Here are some additional pictures.
td25c
indiana
Finished product.
Knoxville TN
Service Manager
Wait a minute! Is that rig you have on the oil pan some sort of home made scavenger pump set up?
td25c
indiana
It is the scavenger pump set up.On the longer 6 cylinder motors,you need the scavenging system in hilly country.
Knoxville TN
Service Manager
Well cover me in gravy and call me country! That's a neat piece of engineering! I like the converter housing adapter plate as well. That's a nice conversion, looks like it was made for it. :notworthy
qball
il
local 150 operator
that's slick as snot on a doorknob;)
td25c
indiana
It works good.The last pic was took two day's ago.Spring is here ,and so is dirt moving time.I like the 16B dozer.
RacinRex
Watkins Glen, NY
Is the adapter plate you built for the flywheel housing just to adapt the bolt pattern on the back of the block or was it to create extra space also?
I've wondered if when bolted to the back of the cummins 4bt the fiat flywheel will be lined up propperly with the torque converter and also if it will fit propperly in the flywheel housing for the fiat starter to work.
I'm taking pictures today during lunch of the beginning of my project and will be posting them as soon as my account is updated.
OCR
Montana
Rancher/Farmer, Wildland Fire Fighter, State snowp
16b engine repower:... only the shadow knows... LOL
That is a nice re-power job!!!... :thumbsup
What's it rated for on horse power?
BTW... Post #2... Picture #3.
Is that a Stetson???... :cool2
OCR... ;)
td25c
indiana
The adapter plate did both.The setup uses two seals,rear main on cummins and torque converter seal in the fiat flywheel housing.The 2 inch thick plate gave a littel space between the two seals.I used the fiat flyweel on the cummins motor.Use a dial indicater to index the flywheel housing.
td25c
indiana
OCR... ;)
Thanks OCR.The cummins is 300 horse.I cut it back a little being the fiat only needs around 200.No Its not a stetson,Its a Tilley bush hat.Its cool in summer and warm in winter,and sheds rain.WWW. TILLEY.com
td25c
indiana
Well the Cummins engine in the Fiat Allis 16-B developed a slight miss in a cylinder last week.It would only miss when the engine was at idle.Here are some pics changing the spark plugs on the job.I also adjusted the valves & installed new fan belts while I had it apart.The new injectors fixed the problem and the fat alice is back in action making noise & moving dirt.
td25c
indiana
Here are a few more pics .I like to "seat" the injectors by giving them a quick snap with a dead blow hammer and I clean & swab out the injector bores whith a wire brush.
