Had to do a little fabricating on the Fiat- Allis oil cooler. The original cooler had two cores,one for the engine oil and the other for the transmission. Both cores are identical. I droped the bottom core & welded hose fittings on the endcaps so I could plumb it to the block & cummins engine oil cooler. Also added a few pictures of the front engine mount & air cleaner mount. Both were pretty strait forward to deal with. Had to enlarge the center cradle on the front motor mount abit as front seal hub was larger on the cummins engine. also had to move the mount forward on the tractor frame about 2 inches & drill new holes. Air cleaner was pretty simple, added angle iron at the rear of the cummins and welded a small piece of steel that bolted in to the rocker box. Used 3 inch exhaust pipe for the turbo to the inner cooler and pvc pipe from the air cleaner to the turbo. LOL
No modifications were needed for the starter as the 16-B used the same series delco starter as most trucks only the 16 starter is 24 volt.
