tool_king
On the way to you . Sent
I will send them to when I get back from scout trip .I have a tl150 with some electrical problems. I've got everything pinned down except drive. If anyone could hook me up with a service manual I will tell stories of your greatness to my children.
My email is deadgrestil@yahoo.com.
The brake in the finale drive may not be releasing . Need check the pressures .I will email the manual books .I just bought a TL 140. When it is first started, it will go forward fine but will only back up with the left side. The right side sticks until you work it back and forth several times then it pops loose and runs fine the rest of the day. Any ideas what to check would be appreciated. If it is still possible to get the service manual emailed that would be awesome as well.
glenbushur@yahoo.com
I will send it to you when I get back to my computer.Ok my turn. Recently fixed my power wire to the ignition. Now no controls at all. 05 ctl 70. Relays are clicking. What next? Where does it go from there? If a manual is available I could sure use it. Email is wrenchdog2000@yahoo.com
To send you the booksThat post is over a year old, did you mean to quote him or mine?
@tool_king , would it be possible to get the service manual for TL130? jgraper05@gmail.com Trying to navigate the shut off after about 5 seconds. Coolant sensor is grounded already.
You get a copy? I tried emailing it to you, but the file is larger than 25mb,so I can't attach.@tool_king , would it be possible to get the service manual for TL130? jgraper05@gmail.com Trying to navigate the shut off after about 5 seconds. Coolant sensor is grounded already.
yes I got a copy. Thank you!You get a copy? I tried emailing it to you, but the file is larger than 25mb,so I can't attach.
