cuttin edge
Here is a non equipment related issue, but I figured you guys would have worked around enough pine trees. I live in a subdivision that was built in the 70s in the middle of a pine stand. Most of the trees are gone now, except on the outside edges. I have cut a few dandies down on my property over the years, and only have 3 100 foot white pines, and a 60 foot red pine left. It is a residential area, but I do have about 3/4 of an acre. besides the red pine, all the trees are close enough to my house to clip it if they fall the right way, but they are all healthy, and barring high winds, and waterlogged ground, I'm not worried. One of the white pines however only about 5 feet inside my line, and could do a serious number on my neighbour's house. She never complains about it, and I always clean up the branches and pine needles on her side. I really don't want to cut it down. It provides a bit of privacy, and the kids hang out under it in the shade. About 45 or 50 feet up, it splits off into 2 main runners. If I were to cut one runner, say this fall, and use something to seal the cut. Then cut the next runner and seal it next fall, do you think it would kill the tree? It has a lot of branches below the 45 foot mark, and I would still have the privacy, and the kids would still have their hang out. If I was going to cut the entire tree, being that it is so close to her house, I would probably get a man lift from work, and limb it from the bottom up, then junk it up as I come back down. Probably do the same if I were to cut the runners to avoid breaking lower branches.
