How can you release the parking brake if it is stuck on? The loader will not move and the parking brake light stays on. There is a hose going to the parking brake that it is behind of the tranny drive shaft. Was told brake needs pressure to release it. Can I take the hose of and plug it then put some pressure to the fitting? Also can the problem be at the valve with the coil for the parking brake.
