I started my Cat 931B today and noticed the amp gauge wasn't showing a charge. I always check since getting the alternator rebuilt. Then I noticed smoke coming up by the left floor board. Several years ago Bob/Ont suggested I run a new wire from the alt. because it wasn't charging and tracing a break in the wire inside a loom would be frustrating. At the same time I put an inline 30 amp fuse on the wire since it provides all the power up to the dash. The fuse was blown a few weeks ago(don't know why) but I replaced it with a circuit breaker and everything was good.
Today the circuit breaker was hot to the touch and when I shut the machine off with throttle the ammeter was showing a discharge. I pulled the circuit breaker out and turned off the key. Then I started the machine to lift the boom so could I get the side panel off. I also took the floor board out and couldn't find where it was getting hot and smoking. The circuit breaker was cool so I put it back in to see if I could find where it was smoking but now the ammeter was showing a charge like normal. I had 13.26 volts at the battery at about 1/2 throttle which I figured was OK because the battery had a good charge. I ran the machine for awhile with the side cover off and other than taking a little longer than normal for the ammeter to stabilize at 1 tick on the + side everything seemed to work normally and the circuit breaker wasn't hot at all. I thought maybe a ground wire was smoking but I couldn't see anything out of the ordinary. Appreciate any assistance on what could have happened and/or what to check?
