1968 Case 580CK
I was wondering why Case failed to put grease fittings on the two rear pivot points (as seen in these pics) of the front end loader. Before painting, I decided to remove the bolt so I could clean and pack fresh grease inside. I greased the bolt, but there is another sleeve that actually rotates which you cannot grease without removing the entire arm. So, I managed to spray lube and oil around the sleeve.....better than nothing I suppose. So, why not have grease fittings back here?
