Andrewk143
Hi I am having a issue with out L150e where it is losing its gears, the machine will run for around 40 minutes and then the issue begins, once in gear it’ll stay in gear but if you flick the lever from forwards to reverse or reverse to forwards you might get a gear or you might not, it’ll show on the dash the lever is in forwards/reverse but then the gear is in neutral, but you can feel the machine click in gear and straight back out and won’t move, turning the engine off and back on does sometimes work but not all the time, gearbox temperature was up to 124 Fahrenheit.
I’m going to take each gear coil off and clean them up, but any other information would be appreciated.
