Underride protection bar
That depends on tire size. According to Utility the bottom edge to ground for under-ride
dot bar is 21" with LP 22.5 tires.
Coaldust
North of the 60
In the future, those specs can be found under CFR 49 - 393.86.
(3) Guard height. The vertical distance between the bottom edge of the horizontal member of the guard and the ground shall not exceed 560 mm (22 inches) at any point across the full width of the member. Guards with rounded corners may curve upward within 255 mm (10 inches) of the longitudinal vertical planes that are tangent to the side extremities of the vehicle.
spitzair
Squamish BC (Home), Slave Lake, AB (Work)
Ok so is it safe to assume then that if the underside of the deck is more than 22" above ground a guard is required? The intent of my original question is how high can the back of the trailer be before I need to install one of these guards.
Pie are Square-No Jethro pie are round.
If the deck is higher than CFR 49 -396.86-22Z-----22" from bottom of deck to ground, then you will have
to add a under ride that is no less than Utility's 21"or 22".
I have thought of retrofitting the company's older tilt with one. It was built well before 98 and is exempt. It would have to articulate.
