ts14 transmission ?
Discussion in 'Scrapers' started by bdmb, Sep 29, 2017.
  1. bdmb
    bdmb Member
    Oct 10, 2016
    13
    manitoba
    I am wondering if anyone knows how much oil goes in to an Allison 4 speed forward 2 reverse transmission. I would like to fill it up then see where the level is on the dipstick. This is on a ts14--7uot. Has a 671 up front with the 4 speed. Allison model CLT 3441-1
  2. RZucker
    RZucker Senior Member
    Jul 7, 2013
    904
    Mechanic/welder
    Wherever I end up
    Assuming by your post, you are in doubt about the dip stick reading ? There should be two 1/8" pipe plugs on the rear cover one above the other. Top plug is full with engine running. The old TS 24s had petcocks in the ports.
  3. bdmb
    bdmb Member
    Oct 10, 2016
    13
    manitoba
    Yes, I am trying to find out how much oil goes into this transmission. The front trans dipstick is a different length than the rear trans dipstick and both have been remarked with grinders. There are no pipe plugs for oil level. This is my machine I purchased at rb auction. Auction means problems. Google seems to be little help as I am finding out. I am waiting on a guy to give me a reply if he can get a transmission suction filter( goes in the oil pan). I don't work on this machine steady so fixing takes a while.
  4. RZucker
    Jul 7, 2013
    904
    Mechanic/welder
    Wherever I end up
    Sorry about the plug locations, I was thinking 5000 series Allison, Check the sides of the main case on a 3000 series, There should be 2 plugs or petcocks about 2 1/2" apart vertically just above the oil pan gasket. I just don't remember which side.
  5. mog5858
    mog5858 Well-Known Member
    Feb 1, 2015
    57
    estavan SK
    i will take a look in my books and try and get back to you i have a guy that can get you most parts out of Regina if parts are a problem. not that knowledgeable with the ts 14 but it should have had a 4-71 not a 6-71 i think you have been re-powered with more HP.
  6. bdmb
    bdmb Member
    Oct 10, 2016
    13
    manitoba
    Thanks for the replies. My problem is that this transmission runs almost twice as hot as the rear transmission. I use a snap on IR thermometer on exactly the same spot on both transmissions and the front trans is around 200*f . I decided that the front trans may have to much oil. I drained the trans oil to look at the suction filter in the pan and saw some stuff stuck on to the glass media(screen), figured I would order a new filter. Well, no numbers on the old filter, and no help from Terex, Wajax in Canada. I found a similar filter on google images, gave Redhead equipment in Regina a number and they crossed it to a Baldwin number. I got the new filter and it is close to what I need so I will modify it and try, but winter set in and the outdoors is my shop. If lower oil level doesn't fix the heating problem then I believe something is wrong on the input side of the transmission because I started the machine up to use air for something and without turning a wheel the transmission temp climbed up at idle.
    The transmission drain plug is magnetic and I saw half of the magnet, so not much filings.
    Finding a filter has taken a lot of time
    First thing I did was to make sure the trans vent is clear.
    This machine looks like the Euclid and I saw some with 6-71 on the internet. ts14b were all 4-71 and 6 speed that I operated back in the 1980s hehe.
    Thanks.
  7. JustinG
    JustinG Well-Known Member
    Dec 21, 2007
    93
    Diesel Mechanic, Cummins
    Commerce, Ga
    Will your TS14 heap up like that without a push dozer? Nice looking TS14, always liked the Euclid front noses.
  8. bdmb
    bdmb Member
    Oct 10, 2016
    13
    manitoba
    Sorry for the deceiving picture. The load is dry manure and was loaded with a loader. Now this allowed me to watch transmission temps because I would load the scraper with a loader while the transmission cooled, then run for 10 minutes to unload and shut off for about 1 hr.
  9. JustinG
    Dec 21, 2007
    93
    Commerce, Ga
    I was wondering because that load looked a little too neat. I've been around a Brazilian TS14B with V6 front and rear, it would load itself, just not completely heaped. I like the idea of a 6-71 in the front.
  10. bdmb
    bdmb Member
    Oct 10, 2016
    13
    manitoba
  11. bdmb
    bdmb Member
    Oct 10, 2016
    13
    manitoba
    I would appreciate it if I could get info of where to get parts. Thanks.
  12. bdmb
    bdmb Member
    Oct 10, 2016
    13
    manitoba
    I would appreciate finding out where I can get parts. Thank you.
  13. mog5858
    Feb 1, 2015
    57
    estavan SK
    Emerald Services Inc
    3091 Industrial Dr N
    Regina SK
    (306) 525-6208
