Hi Aussie Leroy
My name is Sonia I am in Tasmania. We have a 222g scraper that we are in desperate need of a final drive crown wheel and pinion just hoping you could help or are in the know of someone that could help
Bryan, check that the universal joints are perfectly aligned. One tooth out on the spline can cause all sorts of problems
NudgeThanks for your input. We found that the damper on the fly wheel was bad. Also it was not the drive shaft from differential to transfer case but the drive shaft from the engine damper at the flywheel to the front of the transmission. We got a new damper back in it today and will put it back in service in the morning, we'll know for sure at that point. Also I will definitely double check for proper alignment on the splines, that makes complete sense although everything looked right at installation but we will definitely double check that. I will post how it turned out tomorrow evening. Thanks again.
