I do have some very good video, and actually had it put on cd, but I'm computer illiterate and will need help. I'll try to get it done tomorrow. Video will show what (3) TS-18's can produce on a short haul. Quite impressive being pushed by a Cat D8R.
Anyway, here's a few of the guys stripping 'em down, removing the un-necessary baggage.... IE: air tanks, brake manifolds, etc. We're replacing hoses, nylon air lines, looming everything, new seats, re-sealing valves, etc. The normal 10 yr maintenance stuff.
I don't know how you get production with those old, slow machines.
Nice little vid there Jason. Looks like that second scraper took a bit of a jolt, but thats what happens on scraper shows!
A word of advise for your cat skinner- keep the blade up higher and make contact with the scraper on the cutting edge, insted of the center of the blade. By doing that, the slam between the two machines will be reduced because the Cat will kinda slide down at the first bit of contact. Then he can drop the blade into float, or apply some down pressure to help get the can in the ground a little more.
