SVL75 - Shattered Door Window
Laidback1
South TX
Dayum,
Using grapple to clear some cut mesquite brush and BAM, piece of mesquite shot up like it came out of a rifle and shattered the door in a million pieces. Certainly got my attention! New unit, just 35 hours.
I imagine it's not going to be cheap to replace the thing. Problem is what's going to keep it from happening again? I wonder if they offer an option with ballistic glass
Tags
Connecticut
I did this to my SVL90 while brush hogging, it does wake you up quick that is fer sure! My dealer had the glass in stock and I believe it was around 250 or so. I believe they do offer a lexan windshield as an option.
Jimbo
S.E. New Mexico
I have not yet broken the windshield on my SVL90, but understand it will break, eventually.
I priced the lexan replacement at my dealer, and was shocked to hear $2300(complete assembly, frame and all, direct replacement) Holy Schnikies!!!!
Any ideas for a suitable substitute are welcomed.
Laidback1
South TX
Ouch $2300! Looking at non-Kubota dealer options and will report back
JD8875
Harrisonville, Missouri
You can buy lexan/polycarbonate sheet at Lowe's or Home Depot. It's about $200 a sheet if I recall correctly for 1/8". Use the seal for a pattern and cut a new windshield. Prolly get at least two from a sheet.
John
Laidback1
South TX
Got pricing today from Kubota on lexan windshield pre-drilled for the door handle, wiper blade etc. $650. That's if the frame is still usable. Mine's a little bent but I'm pretty sure that I can get it back to shape
Tinkerer
I think you will eventually regret using anything but glass for a replacement. I tried it and it scratches easily just trying to clean it. If you wipe it dry to clean it, it will have millions of tiny scratches that make working in bright sunlight a real nuisance. Others may have better luck than I did but the Lexan / poly-carbonate was a waste of money.
JNB
North Texas
Flyin' low and rollin' slow...
I'm in agreement with Tinkerer. For everyday use Lexan can be pretty annoying. For a flat glass/frame like the SVL's, what about a Lexan sheet that could be easily attached and removed with short standoffs? You'd have to make sure the door would still have room to be flipped up, but I think it's doable.
cdm123
manitoba canada
The Lexan windows are generally a lot thicker than the 1/4" hardware stuff and intended for use with mulchers and hammers etc stuff where it may save your face or life .
Jimbo
S.E. New Mexico
That is what I was thinking; the lexan would need to be at least 3/8" thick, as it is sold by Kubota as a safety device, and recommended for use with grapples, mowers, hammers, etc.....
Tones
Ubique
A lexen screen for my Rayco costs 100 bucks unshaped 12mms thick.1200bucks is a ripoff .I can't buy product to remove the scratches for that.
Polycarbonate is some good stuff but will scratch to beat hell and is not unbreakable in such conditions. Impact resistant yes and a safety feature to eyewear yes in large sheets can still be broken if hit right after has had time to sunbake. In some conditions impact resistant glass and safety glass are still a preference. If working in severe enough woodlot expanded metal stand off removable impact screens would be a cure to broken glass much as the demolition industry uses.
Tones
Ubique
Nothing is unbreakable or idiot proof but I think Lexen for all its down sides is still a much better and safer option.
JNB
North Texas
Yeah Tones, I'm willing to give it a shot.
f311fr1
Middle TN
Contact Shields Windshields. I had them make a door glass with thrie supercoat on both sides for my ASV. The optics are much better than poly and about the same $ as the local glass shop ($331.28) drilled and cut to my pattern. They have the Kubota door sheilds in stock usually. 765 342 2300. They are in Indiana. www.racingshields.com
