greg9504
Hi,
I have a JCB 212s with a Perkins 4 cylinder diesel. I've owned it for several years and never really had a problem starting it in the cold. By cold I mean anything below -10C (14F). I've started it down to -20C (-4F) as long as I have plugged in the block heater. Previous years I always added some diesel anti gel to the fuel before it got cold. This year I didn't. Right before the first big snow I did an oil change and decided to try to drain any water from the two fuel filters. I ended up not removing either filter. I just undid the bottom drain enough until fuel ran out. After I did this it was a bit hard to start, but it did eventually. I ran it for a bit, checked my oil levels, then shut it off. I didn't try to start it again until it snowed a few days later.
Unfortunately I also added fuel to the tank at the same time and FORGOT to put the cap back on the tank. So snow definitely got in the tank.
I then tried to start it after it snowed. It fired right up and ran for a few minutes at idle. Then stalled. I turned it over again and it ran rough then stalled. I then added some fuel line antifreeze and anti gel to the tank. Used a heat gun on the clear fuel filter. Then it fired up and ran fine for several hours while I plowed snow. Shut the machine off and didn't go to run it for a few weeks.
I go to start it yesterday, it's -15C (5F) out, machine is plugged in. Fires right up. Runs for 1 minute, then stalls. I start it again and it runs rough and I try to feather the throttle to keep it running but it eventually stalls and will not start again.
Today I put a heater under it (just a 5000W electric, friend has my 70k btu kerosene heater), a magnetic heater on the fuel tank, and put a tarp over it to trap the heater air. It's -11C today. I leave it like that for a few hours. I try it and it starts, but again only runs for about a minute then stalls. I couldn't get it to run again.
Access to the fuel lines is a hard, as muffler is mounted on top of the engine... so I haven't tried to crack a line.
Does this sound like air getting in (lose filter?) or frozen water in the lines? Or something else?
If I leave the key in the on position (engine not running) I can hear fuel running back into the tank continuously. I didn't think this had an electric pump but I can hear what sounds like liquid moving in the tank.
Thanks for any suggestions.
