Smaller graders
zrt800
mi
I have a old gallion 503 with a IH diesel engine, it works great for small to medium size jobs. Before I bought that I used a AC model D grader with manual angle mold board , it did a good job to the transmision puked.
my engine is bad,cracked block, is there anybody out there that knows anything about a 1955 503g galion continential engine,what is the engine # the metal tag is gone,thanks Lee
zrt800
mi
the 503 i looked at had an ih gas motor in it of the 6 cylinder variety which should have a simular bolt pattern to an ih diesel from a 656, 666, 766, 756,856... and other farm tractors. If you get into 966,1056,1206 and others your talking alot more hp than the drives were designed for. Another good motor to check is the cummings 4-390 series.
will the cummings 4-390 bolt up to my existing bell housing,Thanks Lee
zrt800
mi
502g galion 1955 repower
I have galion 503g 1955 with a bad continential 6 cylinder motor,the engine tag is gone,anybody know what engine#i have,also should i go gas or diesel for repower,anybody have any ideas what diesel motor would bolt up to my bellhousing,i have seen pictures the 503 1955, with diesel engines,thanks,Lee
Scrub Puller
Yair . . .
Graderfan1981
Thanks for you ongoing posts about world graders.
That little Schwab machine is original thinking way out side the box. . . what a perfect machine for road and track maintenance and you can even suck it all together and tote behind a pickup!
Cheers.
repowerguy
United States southern Ohio
mixer truck mechanic
If I can get my son to help me post a pic or two, I'll show you my Hefty G grader, a little machine that is handier than a pocket in a shirt!
cuttin edge
NB Canada
Finish grader operator
We have a Mauldin. It has a nicer cab than the Puckett, and Alitec, but it is not as well built. They narrowed in the lift cylinders on the blade, and I find it hard to keep it on the ground. Give me my old Puckett any day.
DIYDAVE
MD
Wow, 11 yo thread...
Fiat graders were a continuation of the allis D ancestor. I think the M-65 is still being made somewhere...
