Jlicci
New member. I have been following for awhile and learning. I just pulled and repaired both clutches on my d21a6, however I am having problems insallind clluch covers back,is there a trick to this?
Here is the priming sequence for a 1981 D31 Not sure what yours is but the steps will be similar.View attachment 85923
I also purchased and installed a 24 volt battery tender for the winter.
This is a very useful site. Thanks everyone.I recently purchased a d20p-6 and was told by the previous owner to use multi purpose tractor hydraulic fluid for the hydraulic system and 15-40 wt oil for everything else. That sounds simple enough but after reading through the posts most of you seem very strict on using different weights. It is usually fairly warm here but we are approaching winter and might go through a few freezes. Im assuming the viscocity varies with the ambient temps and ours are normally high. Can anyone tell me if this is safe or not. Thanks in advance.
Hi Patrick,
This is the one I purchased on Amazon.com: Battery Tender 022-0158-1 Waterproof 24 Volt Power Tender Plus Battery Charger . It charges and maintains my batteries on my Komatsu D21A-5. What I like about it is that my batteries are always at maximum charge. Thanks, Frank
I have a d21p-6 that we had new steering clutch packs installed August before last because the left side would not turn. It worked for a while but now, it is doing the same thing. I've put maybe 30 hrs on the machine since. The left side pulls, but won't disengage and I thought that the brakes were bad, but when I pulled back both steering handles, it turned right, so the left side is sticking. Before I go back in, can someone explain to me how the clutch pack disengages? I know that there is a small hydraulic cylinder(?) that presses against an arm in the case. What happens to the clutch then? I pushed on that arm and nothing happened. Can someone in the know explain it to this big dummy?
Here is a link to a shop manual for your D21P-6. Maybe it will be of some help.
http://www.megaupload.com/?d=1KJS4J89
Good luck.
Sorry, the above is a dead link. PM me if you need the shop manual and I get it to you.
