On the roller topic, I have read you can build the rollers up with weld but then you may loose the heat treat. After trying to turn the guts of one into something else on the lathe I found they make them really really hard. I ended up throwing the part in the bottom of the BBQ before a long cookout. The next day after everything had cooled down it could be worked with my old noncarbide tooling. You would definately have to disassemble each roller and then weld it and reharden it and then reassemble it.
The manual I got for the D20 was a reprint of marginal quality from SSB (bad picture reproduction). The diagram on page 24-2 shows that there is room to insert a stud thru the access plate hole and thread it into the pressure plate.
You will notice that there is almost no clearance between the pump drive gear and the pressure plate case so I would be very careful turning the engine over so it doesn't accidentally start and tear up everything.
The manual says that the way you have to disassemble the pressure plate from the flywheel is insert the 10mm x 1.5 studs and then crank down on a captive nut enough to compress the springs and pull the pressure plate back off the clutch discs.
i'm thinking that by pulling the pressure off the clutch discs maybe I can loosen the rust that is sticking them together. Then with the transmission in neutral insert a bar to twist the drive shaft which would then try to rotate the discs which would immediately break them loose. Oh course! I'm being optimistic!
I made a copy of the page which i will try to insert as a jpg
If you get to it before I do let us know how it works out. My machine is 2 hours away in the middle of a field north of Waco and me and the shop are here in dallas.
I hope to get back down there by the end of the week.
OldHH
