Scrub Puller
Yair . . . viking1. Good stuff! It's nice to see you up and running.
Cheers.
Cheers.
I'm chiming a little late , but when working on u/c issues I have my sons friends come over , they're football players you know like lifting weights etc. " Bet you can't pick that up". " Ok then you can't put that here while I start these bolts?" On idlers and heavier things you got to challenge 2 of them as a team . They are rough on strong bars and ratchets though.
Cheers.
Yair . . . viking1 . Nice tidy machine . . . what is her purpose in your operations?
You folks in the US call them skip-loaders I think . . . does it have PTO and standard ag. three point linkage or does the grader box have a different system?
Your example has nice chunky looking rubber.
I sure like the hills and cactus in the background . . . I think I could feel very comfortable at you place.
Cheers.
Yair . . . viking1. Nine to see you back.
That sure looks to be a handy machine.
The military used to have them here but seldom do you see them in civilian hands.
Cheers.
Yair . . . viking1. There is something amiss there. Hopefully it is just the guard but I would look into it ASAP . . . high priority in fact.
Cheers.
Yair . . . Good one viking1. Looks like a low dollar fix.
Cheers
Yair . . . viking1. I don't know your machine at all but wear patterns like that can occur when track frames get bent or out of alignment . . . also failing bearings on sprocket shaft only usually in that case they are leaking oil.
Are you sure this is not a residual problem from when you started the thread about "noisy tracks"? I imagine that amount of scrubbing would be fairly noisy.
In other words how many hours have you done since then what with all your other problems?
Cheers.
Check and make sure the idler isn't crooked and binding in the frame, or otherwise stuck
Put a timber between your bucket and idler and use bucket dump
put your idler against a stump and push
