Scrub Puller
Yair . . . Dunno viking1 . . . fan bearings perhaps? I wouldn't run 'til you get it sorted, sounds 'orrible.
Cheers.
Cheers.
Cheers.
Thx Scrub. It really runs fine besides the horrible noise. I also pulled and redid the leaking top cover/shaft on the injection pump yesterday; we had thought lack of fuel was making it miss originally. Have had a long screwdriver (used as listening device) all over machine but cant pinpoint the noise......
Did the noise start when you started it after working on the injection pump leak? If so that is where I would start looking for the solution. Possible that something inadvertly changed in the injection pump causing a bad fuel knock or possible the shaft is seizing. Good luck and keep us posted on what you see and find.
On another note, I just read thru the whole post written over a couple years. If you get around to welding bar on to the grousers be sure to keep the ground cable on the grouser you are welding on. You do not want to take a chance on an arc straying thru a bearing trying to make contact.
Ya. Starts easily, no excessive smoke, no metal that we can see in the oil. I'm leaning towards flexplate too because of the squealing, but also maybe a fuel knock?
Noise was most severe from the front as the first video ran, the second added a screeching noise. Get the pan off, look at each journal on the crank individually, I am suspecting you will find it in the first three rod or main.
I'm not sure if you have drained the oil to come to this conclusion. You won't see the metal on the stick. You will need to drain the pan to see if there is any metal from a bearing failure. I would do this first - before pulling the convertor. If the flexplate HAS failed all drive & hydraulics will stop. If it IS failing, ie cracked, you may get some debris from the hole in the bottom of the bellhousing.
If the engine oil checks out OK, my next port of call is all the tappets, & I still would do a compression test before I would pull the convertor.
Hard to call without being there to really hear & feel the machine .....
Yair . . . viking1. You don't mess around.
I have no knowledge of your engine but it should have done way more than 3500hrs before such a failure . . . I would be looking for reasons, like where does that journal lube from? . . . and make sure all galleries are clear before reassembly.
Cheers.
Nasty!
Make sure you take a good look at the camshaft lobes & the lifters.
A new oil pump should also be considered.
Hope the crank checks out OK for you........ those you tube videos may have cost you more than you realized.....
:drinkup
