Can't remove it, 8 bolts, takes another crane and time.
Threw the blocking forward. Today on my run across the scales, 33,700 lbs on the tandems, and that was with one foot lees boom sticking, I'm at 39' now. A BIG difference in how the headache ball was bouncing around, the fleet angle was much better then at 40'. It will be even better at 38'. Then, back at the yard, I took my 2 or 3 hundred lb. 15 ton load block out. Don't use it often at all, and when I do need I know in advance. It was carried towards the front but will help. Plus I took out a big timber I rarely use, another 80 lbs. Going over in the AM again, and this time I'll have the boom at 38' and see what happens.
As to the overhang issue, that may be easy to get around by getting a over width permit, which I believe also covers length. I asked them once, years ago, how far can I stick out in front (I was carrying some 38' glue lam beams on my 1 ton) and they said as long as you have a permit, no limit! Or words to that effect. The annual permit fee for that is not based on miles driven anyway. I see they are $53.00 annually, just a quick search, not in the mood to study their regs right now. I'll deal with the optimum weight thing first, and deal with the length later.
