I finally had time to work on the tractor. I feel that I may have found the issue right off the bat. The cap nut holding the ASRD on was finger tight. When I pulled the assembly off of the pump (without removing the pump from the side of the engine) the gasket on the stud hole side was saturated with fuel. I replaced the gasket along with the o-rings on that area and put it back on.
Putting the assembly back on was an exercise of feel because it is located on the back bottom side of the pump. I aligned the small rod hanging down from the pump with the stud and raised the ASRD assembly up into place. This is my fear now. It went on too easy So before I try to start or turn over the engine here is my question.
Can the ASRD bolt back in place if the small rod that hangs down from the pump is not in its proper location inside the assembly? Thanks so much.
