Hydraumind
Try to find out all the error codes, active or not active and post them
I've been charging the battery this morning and it's got 24vthe cranking speed should be closer to the 170 mark... but even at 120 it should still build enough to bang..
It's got an active fuel rail pressure very low. First time it happened was 4749 hr and it happened again at 5124 hrTry to find out all the error codes, active or not active and post them
What would be the typical pressureIn the service side of the monitor, go to pre-deifined monitoring. Find the page that says rail pressure and rail pressure command. While cranking see if the pressure goes to what the command says, or close to it.
