Kobelco Hydraulic fittings
Marksan
l want 'T' into this line from my pump to valve bank. ls there a T fitting that i can get?
Also, is there supposed to be a '0' ring in this joint ( ive never seen this kind of joint before, want to make sure nothing fell out)??
Cheers All, :Banghead :Banghead :Banghead
willie59
Knoxville TN
Service Manager
Nope, no o-ring. That looks like a British Standard Pipe Parallel (BSPP) high pressure compression fitting. Fittings and adaptors are out there, I don't know if a tee is available, would have to do some research about that myself. :)
willie59
Knoxville TN
Service Manager
Dominion 410
Ontario,Canada
bspp
That sure looks like the fittings that were used on Poclain excavators years ago. Have seen tee`s on lines like that, but might take some looking to find one.
Dominion
excavator
Pacific North West
If I remember correctly, these Kobelco fittings are the same as the old Poclain fittings. Some hose and fitting catalogs still refer to them as that.
Harry Dart
New Zealand
They're called GAZ fittings, they come in weird thread sizes (27,30,36,45mm) and all use a 1.5mm pitch thread. No O ring used. Check ATCOEQUIP's link above, part number 9247.
We made tees by welding hydraulic hosetails into female tee adaptors.
Do you need to tee into it for a high-flow supply?
xcmark
Foxboro , Ma.
construction
If you can I would suggest putting a JIC "t" in the middle of a flex line and leave the factory ends on the lines. I had a similar issue with my JCB , I ended up changeing out the fitting on my drive motors to JIC and reducing the cost of rebuilding the lines going to drive by 2/3 the cost in parts!
Marksan
Thankyou for the input Gents,
Xcmark; l was just going to post asking that exact question, T into the flex line, remove a section to insure it remains the same lenght.
Harry dart; Yes, 28gpm.
Cheers.
Marksan
Help................................
Could someone tell me which is P4 port??
Cheers.
..................let me know if you need more pics, thanks.
