Bwar77
Hey guys,
*********I got a new issue with my JD 510b, unfortunately before I was
able to fix the old issue (injection pump). This originally started when
I first got the backhoe, I would press the start button on the control
panel and sometimes it wouldn't work, which required repeated pressing.
But it always started. But as time went on, it got worse, more and more
times I had to press it to get it to start. I would press the button,
and if the starter didn't turn over it would give a "click" under the
control panel. It eventually would catch though and crank the starter.
But not anymore. All I get is the click. The starter is still good, as
I've jumped the starter to get it to crank.
Is my problem the solenoid on the starter? Wasn't sure since it was
"clicking" under my instrument panel. And if it is the solenoid, is
there aftermarket solenoid that would be cheaper? I saw the starter
solenoid is about $113 from John Deere...
Thanks for your help, Brian
