I have read the internet stories about it but I do not think it is as bad as they say. I still have my weed whacker, chain saw, lawn mowers, generators, and of course I work on lots of other people's generators and I don't see any problems I can point to as ethanol. Not to say I think it is any good, I think people should eat corn and put petroleum in their gas tanks, or better yet let the market figure it out, but here are the major carb failures I see often:
- Machine left to sit in the rain, water goes into bottom of tank, clogs up float bowl with galvanic corrosion due to dissimilar metals that were never meant to see water
- Machine subjected to dirty fuel, dirt/bugs in gas tank plug fuel lines, etc.
- Machine left to sit a year with fuel valve open, little by little gas from tank flows by gravity and gets distilled off in the float bowl until all that is left is a brown substance resembling dried up wood varnish
This last one is a bit annoying as the horrible smelling MTBE stuff they used to use in the 90s and early 2000s seemed to dry into a white powder that never bothered anything, but the stuff before that dried to the brown varnish like we have now so I guess things go around full circle sometimes.
Birkin this hippie gas blend we have in CA has to much methanol in it. Methanol is hygroscopic and will pick up moisture, well guess what happens to that moisture, it collects. bottoms of fuel tanks and carburetors are the usual places that you're sure to find its footprints.
A friend has a mid 80's corvette they bought brand new, California car zero corrosion. Other than the bottom of the fuel tank that started leaking while they were out of country for a month. Nice surprise coming back to a house that wreaks of gasoline and a car sitting in giant puddle of it in the same room with the water heater.
