diamondtguy
Finished the brackets off yesterday for the cross member.Found a crop of formed 3/8 at work that will work perfect and fit better than angle iron.
Brackets will be welded to the frame.The crossmember sits on top of them so the weight is all supported by the brackets not by the bolts.
The drivers side bracket is long and I will scrap my current t/case mount and it will get built into this one..
I have reversed the procedure in my head and the crossmember will come back out once the brackets are welded on if you remove the trans mount first....
