ichudov
kshansen, this is great to know. I have a forklift with a Detroit 53 engine. Thanks a lot. I learned something new today.
A lot of those detroits have a tank for those drip tubes. A small air tank with a drain valve works perfectly. Drain the slobber tank at every oil change. I've never been around one that didn't leak oil from multiple locations tho. I have heard if you put a 210 degree thermostat in it helps with the oil leaking but I don't know.
I always thought a Detroit was one of the better cold starting engines. If the rack and valves are set right it always seemed they fired like a scared rabbit.[/
Best description yet.....when the Detroit starts, it's like no other diesel: loud and angry. When it's cold, compression is of issue at 22:1......starter trying to hit RPM through cold oil, just doesn't want to kick. I usually warm the coolant with a heater (plug heater, Kats 1500).....works like a charm after about 2 hrs.
That is correct. When I rebuilt the engine, it was obvious the prior owner had not used a CF-II straight 40 oil (they're hard to find anywhere but a marina). The liners were scared and the head looked really bad. I use Rotella straight 40 (not 0-40 or the like). High shear rate viscosity is essential.
I had the engine fired up today, ran it hard for about 30 minutes to get it nice and warm......condensation tends to build up when doing short runs (the oil fill slobbering tube was smoking).
Thanks for posting!
I cleaned the surface with a hot pressure washer, used purple power to get any residual grease off, then wire brushed the surface for flaking paint. Once clean, I applied citrus strip :
http://www.homedepot.com/b/Paint-Pa...paint+remover?Ntx=mode+matchpartialmax&NCNI-5
This stuff worked like magic!! The trick was applying a heavy coat (with a paint brush), let it sit overnight in 50-60 degree weather, then scrape it off. It removed the majority of the paint........with about 10% that needed a second coat or wire brush off. Citrus strip does not put off a toxic fume, nor does it burn your skin (I used rubber gloves to play it safe)......absolutely great stuff!
You cannot put a exhaust restriction on a two stroke diesel, it will not flush the cylinder properly with fresh air.
So, BobcatBob, do you have a twisty neck like a goose and how does it feel to be operating control levers while looking backwards?;-)
Awesome looking pictures! Crane is like new now!
You asked a few days ago how I move my crane on truck. Here's how:
I use this truck/trailer commercially almost every day, you are welcome to inquire. I am in Berkeley, IL.
I'm getting a bid to transport the crane from Elkhorn WI to a shop in Milwaukee. I'll follow up once received (Berkeley to Elkhorn, then to Milwaukee ..twice.....quite a bit of driving). If the bid is crazy, I'll follow up also for "second thoughts".
