Dresser TD 15c converter stall
henry.45
UAE
To check the RPMs in a Dresser TD 15C converter stall accurately, you need a tachometer. This device measures the engine's speed in revolutions per minute (RPM). First, make sure the converter stall is engaged. Then, attach the tachometer to the engine according to its instructions. Start the engine and let it idle. Read the RPM on the tachometer display. This tells you how fast the engine is running. If you're unsure about using the tachometer, it's best to ask someone experienced for help.
How do I accurately check the rpm’s?
