SAE 10w is the oil that most IH machines use in their granny's, TQ. Thicker oil might make it worse. Is the engine doing the correct RPM, could be throttle linkage not allowing full revs. Look for simple things first, RPMs, oil viscosity, filters and suction screen. They will stall out under heavy loads and with sufficient traction. Is it stalling in Lo gear or 2nd, ie the manual Hi Lo lever. Not sure about a 175 TQ, they might have a different stall ratio as in a loader needs more power to the Hyds rather than to the tracks as in a dozer, somebody may know more about that than me. Cheers
